Ir para o conteúdo principal
Informações e guias de reparo para a versão atualizada do Retina MacBook de 2015, lançada no início de 2016. Modelo A1534 / EMC 2991
Boot sequence issues and full blast fan while running
Good day, I have a 2016 MBP, battery is dead and i need to be plugged in to use it.
The issue is, i need to press the power button then plug it in to make the MBP start. Then the fan is in full blast while im using it.
Just upgraded to Sonoma via Opencore, works great.
My Main question is; what is the issue when starting the laptop. is there a hardware problem?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Given the systems age I'm suspecting the battery has failed, install this Gem of an App CoconutBattery it will allow you to see mot]re clearly the batteries health. Post a snapshot of the Apps main window here so we can see as well.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hi @Dan, Yes i think the bat is dead. WIll changing the battery help in booting process issue? and Fan on full blast?
por Compartilhar
@jujoe - If the systems sensors are telling SMC there is a problem, the SMC logic will lower the CPU's clocking as well as pump up the fans RPM as it's going into CPU Safe Mode. I suspect that is what you are seeing which is likely the Battery, but without proof of seeing the CoconutBattery screen shot I can't tell you it's the battery alone.
por Compartilhar
Adicionar a sua resposta
jujoe1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 212
