Ir para o conteúdo principal
Anunciado em 28 de setembro de 2023, o Raspberry Pi 5 atua como uma revisão do hardware do Raspberry 4B.
Pi is not booting up
I connect ot to the power supply and it shows red light, (my pi camera was shorted and burnt a bit from since my pi is showing red light) it is not showing green light, fan doesn't spin and a minor current i feel when i turn it on any fix?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
troubleshooting steps:
  • See if a pc can recognize the device.
  • Reprogram the firmware
  • Check if the SD card is working properly
  • Check the voltage rails on the GIPO header pinout is found here
Imagem
how to change boot mode and other pi hardware documentation is found here
Esta resposta foi útil?
Pontuação 0
@prasadgawas since this happened because "my pi camera was shorted and burnt a bit from since my pi is showing red light" you do want to go ahead and repair that damage. Anytime you have a shortened component you will have top replace it first and check all of the traces as well as other components which may have shortened out as well. Go ahead and post some good pictures of your Pi5 with your question so we can see what you see.
Since this is physical damage, no firmware update etc. will work for this
Pontuação 0
Adicionar a sua resposta
Prasad Gawas será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 630
