Ir para o conteúdo principal
Fabricada pela Weller, Modelo nº 8200PK, produzida desde pelo menos 1967.
Not reaching operating temperature
My Weller 8200 140/100 watt gun stopped reaching operating temps. I've covered the basics like assured good, clean contact for both points of the interchangable tips. And tested the continuity which seems to be good. The trigger switch is operating correctly. Any help would be much appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Hi @humanilegion
Is this happening on both the 100W and 140W setting?
If so check that the nuts that hold the tip in place are tight.
Esta resposta foi útil?
Pontuação 2
You must calibrate it again
Pontuação 0
Common Causes & Fixes
  • Loose Tip Nuts: The copper tip carries high-current low voltage directly from the transformer secondary, acting like a resistance-spot welder. If the two retaining nuts holding the tip are even slightly loose, electrical and mechanical resistance increases, drastically dropping output wattage (e.g., dropping from 140W down to 67W).
    • Fix: Loosen the nuts, clean away any oxidation, and firmly tighten them down using a 3/8-inch or 5/16-inch wrench. As the copper tip heats and cools, it shrinks and can lose tension over time.
  • Tip Oxidation and Wear: Heavy corrosion, carbon buildup, or a heavily worn, thinned-out copper tip prevents proper current flow and heat transfer to the work.
    • Fix: Remove the tip, clean the contact studs and the tip loop with sandpaper or a wire brush, or replace the tip entirely.
  • Trigger-Switch Issues: The mechanical trigger switch can develop pitted, oxidized, or burned contacts inside the housing, failing to deliver full current to the transformer primary winding.
    • Fix: Inspect the switch contacts for burning or clean them carefully, or replace the switch assembly if it fails continuity under load.
  • Transformer Degradation or Burnout: Prolonged use or ignoring the recommended intermittent duty cycle (such as holding the trigger down too long without rest) can overheat and damage the internal transformer.
    • Fix: Test the transformer secondary output with a low-range AC voltmeter or check if the gun hums and vibrates normally when the trigger is pulled. If the transformer winding is burned out, the unit usually requires replacement.
  • Does the gun still hum or vibrate when you pull the trigger?
  • Does tightening the tip nuts change the heat or hum level?
Pontuação 0
Adicionar a sua resposta
humani LEGION será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 32
Ao todo: 300
