Difficulty finding the cubic foot
Cubic foot? model number 110.28102310 wife says its a double loader
Esta é uma boa pergunta?
Hi @hotknife
Most Kenmore 110 series washers have a cubic capacity of 3.2 cu.ft.
The owner manual doesn't specify the capacity of the washer, only the soil level types but you can work it out using the formula used to find the volume (capacity) of a cylinder i.e. the tub (drum) is a cylinder
V= Volume (capacity), r = radius of tub i.e. measure the diameter of the tub and then halve it and H = height of tub i.e. measure the height of the tub from the bottom to the top of the tub.
If using inches as the measure then ensure to make the radius and height values measurement relate to feet e.g. 16" = 1.33', 27" = 2.25' etc to get the answer in cu.ft
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 55
Ao todo: 763
