Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
A/V Cables not working properly
Last night on the ps3, I was playing mw2(2 thumbs up for infinity ward). While playing I had a graphic issue using my HD conpeont cables that i bought for my ps3.
I don't know if the a/v cables went bad or the ps3 died. How can I find out?
If it is the cables, what kind should I get?
And by the way i have Monster Game Conpeont cables for my Ps3 fat
p.s. i own a 2usb 80gb
(400$$)
Esta é uma boa pergunta?
Pontuação -1
4 comentários
unintelligible, again
por
I need help with this
por
thanks nat welch now i know how to ask this
por
right now im using SD cables i had from a ps2 that broke
por
Adicionar um comentário
2 respostas
Solução escolhida
You can also try a different set of cables including if you have it the stock AV cables that came with your system. Also try a different TV set or Monitor and see if that works.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Thanks so much Nat for the translation and spelling. Who says the older generation can't communicate with the younger? This type of machine fails so many times due to cheap cables and heavy use that I would never go the cheap route. Go to Radio Shack and get the best they have. If the PlayStation is bad you will always be able to use them with a newer machine. I prefer the "Monster" brand. http://www.monstercable.com/
Pontuação 1
6 comentários:
As an audio technician, I respectfully disagree about Monster cables. In the sound industry, nearly everyone agrees that they are overpriced and not worth it.
por
thanks i have a jvc tv from may 2004 and i have monster cables
por
Josh, if you have a constructive comment, then you need to try to answer the question yourself. You offered no alternative, just criticism.
por
I'm sorry- I didn't mean it as criticism. I simply meant it as a way to save the chap some money if he needed new cables. I tried to convey that, but I guess I failed. I apologize.
por
Thanks. As an audiophile what cables do you recommend?
por
Exibir mais 1 comentário
Adicionar a sua resposta
Nick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 1,294
