Ir para o conteúdo principal
A Máquina de Lavar Maytag modelo MVWB765FW é uma lavadora de abertura superior com opção de enchimento profundo. A lavadora tem um volume de 133 litros.
Agitator not working properly
Why is my washing machine is making a horrible grinding noise while the clothes are supposed to be washing, but the agitator isn't moving? Is this something I can fix? Single mom with no money to call someone. Adding a video so you can hear the noise.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @mlalfor77
Please confirm the full model number of the washer?
Reason for asking is that there are 5 model variants beginning with MVWB765FW... and they may not all use the same parts if a replacement part is needed.
por Compartilhar
@jayeff
MOD is MVWB765FW3
SER is C90470446
TYPE: 589-02
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @mlalfor77
Could be that the splines on the agitator have worn down and it is slipping on the transmission shaft. Worst case would be if the corresponding splines on the transmission shaft have also worn down as well.
Here's a video that explains how to replace it. The agitator part number shown in the video i.e. W11550891 is the one for the agitator used in your model washer.
Search online for W11550891 to find suppliers that suit you best. (examples only)
Imagem de Agitates clothes effectively in Whirlpool and Maytag washing machines.
Produto
W11550891 - Whirlpool Washing Machine Agitator
$61.99
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Melissa Alford será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 69
Ao todo: 932
