Ir para o conteúdo principal
Um notebook Dell XPS 15" 9575 (2 em 1), fabricado em 2018.
How to replace internal keyboard?
I’m asking because I don’t know what to do at the stage when you see black polyethylene. I can’t find the complete replacement instructions.
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @galaxyvitas1143
Here's the service manual, taken from this support webpage for the laptop.
Go to p.52 to view the procedure to remove the palm rest and keyboard assembly.
Basically you have to nearly completely disassemble the laptop to do this.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Well, the instructions only show the entire keyboard block with the case. I just want to replace the keys inside
https://imagizer.imageshack.com/img923/4...
por Compartilhar
@galaxyvitas1143
You'll probably find that the keyboard is fused or riveted to the upper case, so you will have to either melt the plugs or drill out (break) the rivets that are holding the keyboard in place.
por Compartilhar
Adicionar a sua resposta
Galaxyvitasa Galaxyvitasa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 437
