Ir para o conteúdo principal
Lançado em julho de 2018, o MacBook Pro de 15", modelo A1990, possui uma tela de 15,4 polegadas com retroiluminação LED e tecnologia True Tone, TouchID e processador Core i9 de até 6 núcleos.
Water damage, need component of schemat
Hi, after water damage, the Touch Bar does not power on. I purchased a new bar, but found different damage and need to know the type and the value to potentially replace it. Not sure if that is a bar bar-related thought.
Looks like a resistor to me, but need to find a value and the size. Not sure how to describe a connector where the component is places, so hopefully somebody will recognize it.
Have a look at the images. It is a MacBook Pro 15-inch 2018.
Thanls
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@michalaugu27500 that is an inductor (Ferrite bead chip). Reference designator for that is L8504 and it is a FERR-120-OHM-1.5A in a 0402 package. Something like this will work. Mouser is heavy on shipping costs so make sure you make ordering it worth the cost of shipping. Of course, you can purchase wherever you like. The link is just an example since I purchase my components either from Mouser or Digikey, but it is not an endorsement. No, I don't receive kickbacks :-))
Esta resposta foi útil?
Pontuação 1
2 comentários:
The trace is gone, and I think the left side burned was a vias, and it's gone as well. You don't have a schematic, do you? I wonder if I can route it somewhere else.
por
@michalaugu27500 try here If you have no luck or can't sign in, send me an email.
por
Adicionar a sua resposta
Michal Augustyniak será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 196
