Ir para o conteúdo principal
How to fix adapter
How to fix adapter
Esta é uma boa pergunta?
Pontuação -1
3 comentários:
Hi @sabahemmanuel
More information is needed to help you.
What kind of adapter i.e. power adapter, cable adapter etc?
What is the problem with the adapter?
Post an image of the adapter in your question showing what the problem is if it is a physical problem i.e. broken. Here's how on ifixit Adicionar imagens a uma pergunta já existente
por Compartilhar
Power adapter for laptop. The one with the big pin
por Compartilhar
I will send the image to you but is not with me now
por Compartilhar
Adicionar um comentário
1 resposta
Hi
Most laptop adaptors are sealed switch-mode power supplies. If it has a damaged connector or cable you could fix it if you can solder. But you will find cheap Chinese knock off adapters on eBay for less than the price of the parts and used genuine adapters at a decent price. You probably aren’t fixing it, but you should ensure the power supply is the issue by checking the voltage across its connector if it does not have a physical problem.
Best regards,
Robin
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sabah Emmanuel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 22
Ao todo: 265
