Ir para o conteúdo principal
Guias de dispositivos e reparo para o smartphone Huawei P30. Smartphone topo de linha da Huawei lançado em março de 2019, apresentando uma tela OLED de 6,1" e um sensor de impressão digital integrado na tela.
My speaker is not working
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@nkohlalakayy place your phone in safe mode and see if the speaker works in that. If so it is a 3rd party App that is blocking your speaker. You will have to uninstall those. To put your P30 in safe mode, first turn it off. Then press and hold the Volume Up and Power buttons while turning it on until you see the "Safe Mode" option.
If it does not work in safe mode either, consider replacing the speaker. To do so and since iFixit does not yet have a specific guide for this, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nkohla Lakayy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 22
Ao todo: 233
