Ir para o conteúdo principal
Segunda geração do iPhone. Modelo A1241 / capacidade de 8 ou 16 GB / parte traseira de plástico preta ou branca. O reparo é mais direto do que no primeiro iPhone. Requer chaves, alavancas e ventosas de sucção.
Charger keeps connecting/disconnecting
When I plug it in it shows that its connected and then disconnected and connected and so on but when I unplug it it dies right away, when I try to restart it by holding power/home the screen flashes and then goes back to the same thing, its weird because when I first got the phone I few days ago it was working normally with the battery and everything, I took out the vibrator out of the phone because it was broken but I’m not sure if that’s the problem, and it’s not the charger because it works fine with the other devices.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Try a new battery. If it still has the original it won't be too healthy.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Isn’t there a way to power it on without the battery or make it show any signs of life ( like soldering another battery or a usb cable )
por
Adicionar a sua resposta
Titan Saleh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 38
Ao todo: 266
