Ir para o conteúdo principal
Unused part in Airport Extreme upgrade
Due to the phillips screw being too tight, I was unable to complete step 14 in the guide to upgrade to Airport Extreme.
The screw in question holds what appears to be a grounding contact.
Airport works fine without it.
Am I putting my Mac at risk by having the Airport Extreme card not grounded (if it is a route to ground)?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I believe that grounds out to the top case.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Maybe both, as the contact was in touch with a fine metal mesh tube on situated just above the left USB ports.
por
Pergunta mais útil
Probably not, the airport card makes contact in many other places other then that contact.
Pontuação 2
Adicionar a sua resposta
Paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,114
