Ir para o conteúdo principal
Lançado em 22 de novembro de 2005, o controle sem fio Xbox 360 é o principal controle de jogo para o console de jogo Microsoft Xbox 360.
My controller is not working
Esta é uma boa pergunta?
Pontuação 0
10 comentários
Hi!
What isn't working?
por Compartilhar
I don't know when i press the x butoon but controller is not on/working
por Compartilhar
Does it show the green light? Does any light burn? Do you use batteries or a rechargable battery pack? How does the battery springs look? Can you share a photo? Thanks!
por Compartilhar
No. yes i use cell .
por Compartilhar
Most likely motherboard related, or battery spings. How do they look? Still fine? No corrosion?
por Compartilhar
Exibir mais 5 comentários
Adicionar um comentário
3 respostas
Solução escolhida
Thank you for the pictures!
All right. There is corrosion on it and thus it is recommended to replace them!
First, you need to de-solder those from the motherboard and solder new ones back in.
Second, the battery cover need to be replaced as well.
You can get the battery springs here: 5Pairs For xbox 360 Replacement Wireless Controller Battery Springs - AliExpress
You can get the battery cover here: 2-4pcs For XBOX360 Game Controller Battery Back Pack AA Battery Holder Cover Case Replacement for Xbox 360 Wireless Gamepad - AliExpress 44
If you have any more questions, please let us know!
Esta resposta foi útil?
Pontuação 1
4 comentários:
No i did not want to change any thing tell me how to clean
por Compartilhar
You can try cleaning, the only thing you can do is to clean it with isopropryl alcohol. Hopefully that will get it back to work!
por Compartilhar
Hello i want to unlock my ipad air 2 without paswrod i forget my pasword tell my how to unlock
por Compartilhar
You mean the Apple activation “find my” lock? This cannot be unlocked. You need Apple for this. You need to show them proof of purchase and then they can unlock it for you. But please create a new thread for this. This thread is about an Xbox 360 controller.
por Compartilhar
Veja o conteúdo da imagem:
Pontuação 0
1 comentário:
Can you also show the back side where the battery springs are? Thank you!
por Compartilhar
Imagem
Pontuação 0
Adicionar a sua resposta
Klamani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 868
