Ir para o conteúdo principal
Caixa de som Bluetooth portátil lançada em junho de 2015. A caixa de som apresenta a tecnologia ClearAudio+ e a tecnologia LDAC. Número do modelo: SRS-X55.
I need help with an issue.
Hello!
I have a Sony SRS-X55 Bluetooth Speaker that is with an issue, which I am trying to solve. However I will describe the issue below.
I spilled water on my speaker’s power button and call button and after this incident the speaker did not turn on anymore;
I tried resetting and charging my speaker multiple times. Therefore both actions did not work. The speaker does not turn on nor it keeps the charging light on while it is plugged in the power outlet of the wall like it use to before the incident.
The battery was still good in my opinion despite never being changed before, because I rarely used this speaker and it was fully functional holding a charge earlier this year until recently when I spilled water on the speaker's power button and call button.
My questions are as follows:
1) How do I solve this problem?
2) Which part could be the faulty one which needs to be replaced more likely?
Looking forward to someone's help.
Sincerely,
Jorge Nicholas.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@mrfixit50969 this could very well be the button board. Time to take it apart by using this guide Sony SRS-X55 Button Circuit Board Replacement - iFixit Repair Guide Next you want to clean that with some high-grade (90%+) isopropyl alcohol and a soft brush. Check the board for any damaged components. It might be helpful to post some front and back pictures of the board to see if we can find anything "odd". Use this guide Adding images to an existing question - iFixit Repair Guide for that.
Which part could be the faulty one which needs to be replaced more likely? Unless ruled out, my prime suspect is the button board.
Imagem de iFixit
Guia
Adicionar imagens a uma pergunta já existente
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Sony SRS-X55 Placa de circuito dos botões
Guia
Substituição da placa de circuito dos botões do Sony SRS-X55
Moderado
5 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mr.Fixit será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 253
