Ir para o conteúdo principal
O que há dentro de um chip? Como ele funciona? Os chips de computador também são chamados de circuitos integrados, circuitos integrados monolíticos, CIs, chips ou microchips.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Imagem
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
por Compartilhar
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
por Compartilhar
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
por Compartilhar
Adicionar um comentário
1 resposta
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
por Compartilhar
Adicionar a sua resposta
TechVid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 253
