Ir para o conteúdo principal
Smartphone topo de linha da Samsung com caneta stylus, sucessor do Note8, lançado em agosto de 2018. Possui uma tela de 6,4" e até 512 GB de armazenamento interno.
Stuck in a BootLoop
I my phone keeps rebooting whenever i turn on the phone or even when i plug it in to charge. It just pops up the "Sansung Galaxy Note 9" logo and the switches off again repeatedly. sometimes, it even takes me to "Android Recovery Mode", and i have also tried factory reseting it, wiping the catche partiton and restarting it again but nothing works. What do i do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Here’s what to do:
1. Your phone’s software might be messed up — you gotta reinstall the official system (called firmware) using a tool called Odin on your PC.
2. If that doesn’t work, your battery might be dying and causing the phone to freak out. Try swapping the battery.
3. If still nothing, some hardware inside your phone might be broken, and that’s a pain to fix without a pro.
So, first try flashing the system with Odin, then change the battery, and if it still sucks, get help or consider replacing the phone. Simple.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Wisdom Simeon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 373
