Ir para o conteúdo principal
O Xiaomi Redmi Note 12 4G/12 4G NFC é um smartphone intermediário da Xiaomi. O Redmi Note 12 4G foi anunciado e lançado em 30 de março de 2023. Este celular possui uma tela com taxa de atualização de até 120Hz.
My Redmi note 12 Camera is done
My Redmi note 12 Camera doesn't work anymore, I tried everything, the repair shop said it's a hardware problem, and they can't get inside a Redmi, it was also Brand new, One day before the camera completely stopped working, I saw fog, inside the camera when I woke up,
I think there is a small plug that got loose, The flash is also Not working, So No camera and no flashlight. I just wanna go inside the phone, and connect that loose wire that I think is the problem, Anyone have an idea of what it might be ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
@sampiaimar this "I saw fog, inside the camera" means that you have had water in your camera. I just think you got more going on here then just a loose connector. You will also have to tell us which camera, since your phone has multiple.
Anyhow, use something like this video to get into your phone and to check things out.
Esta resposta foi útil?
Pontuação 0
Pontuação 0
Adicionar a sua resposta
Sampi Aimar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 563
