Ir para o conteúdo principal
{A1706 / EMC 3071}—Lançado em junho de 2017, este MacBook Pro de 13" possui processadores Kaby Lake de até 3,5 GHz Core i7 com Turbo Boost de até 4,0 GHz.
How to fix/replace component underneath the key piece?
My E key has been missing for a while, but the component underneath still worked when pressed. Now, it’s no longer working. Can I replace just that break, or do I need to order a whole keyboard? TIA
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You should be able to replace the scissor mechanism as well as the rubber bumper. Here is a source for the needed parts TheBookYard - MacBook Pro keyboard parts click on the image to dig into the different caps and other parts.
Esta resposta foi útil?
Pontuação 0
@valeriasan26150 here is the A1706 Keycap Replacement procedure. Take a look at page 2 for the explosion drawing on your keys. Although keycaps can be replaced, the butterfly and switch housing cannot. A damaged switch housing or butterfly requires replacement of the entire top case.
Pontuação 0
1 comentário:
Sorry OT I’ve replaced them using this part Keycap Mount and Dome - Alphanumeric
por
Adicionar a sua resposta
V santi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 226
