SIM card door locked
I can't open the SIM holder, it seems to be stuck; how can I remove it to take out the SIM?
I tried using a paper clip, but it doesn't click because it seems stuck.
Esta é uma boa pergunta?
This one can be tricky because you dont want to force anything causing damage. Do you have access to a proper sim eject tool? I know a paper clip should and will work, however, I have had this very issue you are explaining. Worst case scenario is that you will need to remove the back and reset the sim eject pin. It's a black plastic pin near the sim tray that looks like a tiny cylinder.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 20
Ao todo: 234
