Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas para o smartphone Xiaomi Redmi Note 11 4G, lançado em 1º de dezembro de 2021. Identificado pelo número de modelo 2201117TG.
How to fix draining battery
Yes, so my battery sometimes drained so fast, like i just unplugged my phone from charging from 100%, after 20 minute, it's already 93%, and when i play game, it's drain fast, i was playing a game, and the battery is 14%, then its suddenly died,
Imagem
, i already check the battery health in the settings, its showing my battery draining so much, please, how to fix this.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
My Xiaomi went from 100 to 60 in ten minutes without me using it, and shortly after it shut down, and started up right after, but as soon as I did something with it it shut down,And now it only charges up to 40% and shuts down as soon as you do anything with it, this happened after it had the battery changed by the phone rep,
por
Adicionar um comentário
1 resposta
Solução escolhida
@saad74735 you spend over 50% of the time playing games. Games are really hard on the power consumption of a cellphone. Also, if this is still your original battery, you do want to change the battery. It is kind of getting old. . After that, either decrease the time you play games or purchase a phone that is meant for gaming. There is no fix since this is normal
Esta resposta foi útil?
Pontuação 3
1 comentário:
thanks for the answer bro, appreciate.
por
Adicionar a sua resposta
Saad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 45
Ao todo: 750
