Ir para o conteúdo principal
Um Passat totalmente novo, baseado na plataforma B5 do Grupo Volkswagen, foi lançado em 1998 na América do Norte.
Charging problems with battery
My battery won't charge
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
@shirleylar63859 let's start off by clarifying what you have checked. Have you checked your battery? Have you checked your alternator? Use a voltmeter and measure the battery voltage between the positive and negative post. It should be around 12V Next, with your Passat running measure the voltage between the positive and negative post. What voltage do you get (expected is around 13.5V to 14V DC). If you have that voltage, it is most likely your battery. If you do not have that voltage, it could be your alternator. Let us know what you find out.
Esta resposta foi útil?
Pontuação 1
well, you must start by doing something and letting us know what you did.
Your question is like my car won't run. What's wrong?
Start by taking it to AutoZone or Advance Auto, They can check the battery and alternator.
That alone will likely get you an answer.
Pontuação 0
Adicionar a sua resposta
Shirley Larson (Squirrel) será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 165
