Ir para o conteúdo principal
Em vez de depender de radiação indireta, convecção ou condução térmica, a indução usa os aspectos magnéticos da panela de metal para oscilar o campo magnético, o que resulta em aquecimento resistivo para cozinhar os alimentos.
Correct connector to UI PCB
Siemens iQ700 Flex induction cooktop EX375FXB1E
My Induction plates fan died. I tried disassembling it but when I did, the UI PCB was partly glued to the glass top. It was retained by the connector so I disconnected it. I hadn't noticed that there were multiple possible connection point on that PCB and there are no markings.
So now that I'm assembling it back, I am left wondering which would be the correct connection point. How can I find this out?
See attached photos
Imagem
Imagem
Update (03/27/25)
Adding a few more photos of the teardown in case someone search for ifixit and that model name in case it's useful to them.
Imagem
Imagem
Originally I thought the fan was broken because there were a lot of pieces of plastic that were rattling around (from shipping this induction plate despite it being protected by foam in the package) but actually what broke is the plastic below each induction zone. I don't think it's a huge issue so will be testing the it soon (need to find time to hook it up)
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @giommm
You would need either the service manual for the cooktop or the schematic for the board to know for sure.
I couldn't find any service information about the model online.
What I did notice though is that when you zoom in on the 2nd image you posted so can see marks on one of the board connector tabs showing that a plug connector may have been there which don't seem to be on the other similar board connectors.
Here's a zoomed in image showing where to look. Note the red arrows pointing to scrape marks and the green arrows showing dents in the tabs whereas they don't seem to be on the others on the board
You may be able to see it more clearly though when looking directly at it.
Imagem
click on image)
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks, good catch! when looking closer, you're completely right about the mark. Between this and the way the cables of the connectors are bent, I'm pretty sure this is the correct place.
I did try to search for a service manual first, it's annoying when manufacturers like Siemens don't publish it.
I'll test it in a few days and confirm if everything works.
por
Adicionar a sua resposta
Giom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 334
