Ir para o conteúdo principal
O MSI GP62MVR 6RF Leopard Pro é um laptop gamer lançado em 2016. Ele apresenta um contorno vermelho e o logotipo da MSI exibido na tampa. Número de série: K1610N0067741
About the CMOS stack
Hi, I wanted to know where I can find the KTS 67 CR 1220W 3.V CMOS battery? And where to buy it, because I'm seeing different models, and I don't know if they're right for this computer.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@davidherna88348 that will be a common CR1220W 3V Lithium battery. You can get one like this and splice the wire to maintain your connector. Of course, you can also look at places like this and even Amazon sells them for a small fortune. So, always be aware that you can get poked in the eye :-) The only thing that matters for this battery is that it is a CR1220, because that is the physical size and that it has 3V. Stay frugal and save your money.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 2
2 comentários:
And is the connector a JST or Molex? I can't quite identify it, and is it 1.25mm? Thank you very much.
por Compartilhar
@davidherna88348 the expensive batteries are the once that supposedly fit your motherboard. So that means that whatever is on your board should be compatible. I like „cheap“ and just connect the wire from the old battery to a new one by splicing. That way I do not rely on OEM batteries and save my hard earned money. :-)
por Compartilhar
Adicionar a sua resposta
David Hernando será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 25
Ao todo: 320
