Ir para o conteúdo principal
The Craftsman Walk Behind Mower 917.388940 is a gas-powered lawn mower with a 6.0 horsepower engine and 21-inch cutting width, designed for non-commercial use. This page provides repair and information about its features, including manual push transmission, rear bagging, side discharge or mulching capabilities, 6-position height adjustment, and more.
Is there a rebuild kit for this engine?
Rebuild kit for 6hp Briggs engine.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@matiasfcoloma see if you can find an engine number. that'll help us to locate the right rebuild kit.
por
Adicionar um comentário
1 resposta
Hi @matiasfcoloma
If the engine is a Briggs and Stratton (B&S) 22K02-0577-E1 then depending on what parts are needed, there are a lot of results showing the parts list that may help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matias F. Coloma será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 22
