Ir para o conteúdo principal
O Lenovo ThinkPad X1 Tablet (3ª Geração) é um laptop de 13 polegadas que pode alternar entre tablet, laptop e tela de desenho, semelhante a um Microsoft Surface Pro.
Touchscreen Not Working in Windows 11
After I upgraded to Windows 11, the touchscreen doesn't work anymore. How to fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @raydyliacco
Check the status of the touchscreen in Device Manager to see if it is installed correctly or whether it is disabled etc.
Go to Device Manager > Human Interface Devices > HID Compliant touch screen.
  • If there's a red cross next to the entry, right click on the entry and select Enable device. Then right click on the listing again and select Properties and check in the General tab, that it shows "this device in working properly" in the device status box.
  • If there's a yellow exclamation mark next to the entry, right click on the entry and select Update drivers and follow the prompts. You need to be online for this to work.
  • If there's no Compliant touch screen entry shown, click on Device Manager > View > Show hidden devices and search through the categories to see if you can find it listed anywhere in Device Manager.
To get to Device Manager in Win11, press the Win key + x key (both together) and click on the Device Manager link in the menu box that opens.
Esta resposta foi útil?
Pontuação 0
1 comentário:
thanks that also helped me my nig
<3
por
Adicionar a sua resposta
Ray Dy Liacco será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 14
Últimos 30 dias: 64
Ao todo: 1,157
