Storage not showing on pc
My laptop tells me there is no storage. I cant find my ssd storage
Esta é uma boa pergunta?
@aon9472 check your BIOS settings and see if your BIOS still shows the storage. your computer should not be using a SSD. It uses embedded eMMC. The eMMC "drive" is soldered to the motherboard. It is possible that it may have failed. You could check on here to see if that helps to diagnose it. To actually work on your laptop, use the HP Stream 11 Pro Maintenance And Service Guide
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 189
