Ir para o conteúdo principal
O Lenovo ThinkPad E540 foi lançado em agosto de 2014. Ele pode ser identificado pelo número do modelo: PF-01G2R9.
Can I add second ssd?
I'd like to know if i need any hardware to install a second ssd in my e540 laptop. Wether i have to take the DVD out i dont care.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @techartsso31230
Assuming that you've replaced the sata HDD with a sata SSD and you want to add a 2nd SSD then you don't need additional hardware to install it.
You can remove, if you don't have (or want) the WWAN card (not the WLAN WiFi card) from the motherboard and insert an M.2 2242 SSD in the port in its place.
Here's the hardware maintenance manual for the laptop. Go to p.72 to view the procedure to remove the WWAN/M.2 card.
If you want to keep the WWAN card and insert a 2nd SSD then you will need to remove the dvd drive and insert a caddy with an SSD in its place. Go to p.68 to view the procedure to remove the dvd drive.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
TechArts Solutions será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 289
