Ir para o conteúdo principal
Câmera digital compacta de 16,2 MP com sensor Exmor R CMOS, tela touch OLED de 3,5 polegadas, 3D Sweep Panorama e gravação de vídeo Full HD 1080/60p (Preta) Data de lançamento: 12 de janeiro de 2011
What is wrong with my screen?
There is a big white line on the screen of my camera. It works just the same nothing is wrong with it other than that. I placed it on top of my game console and when I went to use it today, there was a big white line on the screen. What do i need to fix it.
Imagem
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Hi @gamingwithchris
Is the line showing up in pictures taken by the camera and then they're downloaded and viewed on a TV. monitor etc?
por
Hi! It’s a line around the middle of the screen. It’s not in the pictures I would say, it’s on the whole screen no matter what mode I put it in. I haven’t tried to download it onto another device but as of right now it goes from the top of the display to the bottom. And when I try to change the brightness of the screen, it doesn’t affect the white line, it stays very bright while the screen does not
por
@gamingwithchris
You need to verify and not guess whether it is just seen in the camera screen or if there's also a line seen in pictures taken by the camera, downloaded and viewed on a different screen
If it is in the LCD screen in the camera only then most likely it is the screen that it the problem and it can be replaced.
if it is in pictures also then it may be a motherboard problem, a lens problem or both.
Post an image showing the line in the screen here's how on ifixit Adicionar imagens a uma pergunta já existente
por
@jayeff I have added the image, and I also verified that is just on the camera screen, I viewed the pictures on my computer and they are perfectly fine.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @gamingwithchris
It's looking like a problem with the OLED/LCD display in the camera.
Here's the ifixit Substituição do conjunto OLED/LCD da Sony Cyber-shot DSC-TX100V guide that shows how to replace it.
There are a few suppliers found online when searching for Sony Cyber-shot DSC-TX100V LCD replacement part
There's no part number shown for it in the service manual parts list
Perhaps there's a part number on the back of the screen that you can use to search for more suppliers.
@gamingwithchris
Yeah, I found that website also and searched through all the parts but none of the descriptions seemed applicable to the screen.
Wasn't really surprised as it's not listed in the service manual parts list either.
The only reference to it is that it is designated as component EL901 and is comprised of an LCD screen, a touchscreen and a backlight circuit.
As I suggested, check if there's a part number on the back of the display or on the flex cable coming out of the display and search online for Sony (insert part number) and hope that there's more suppliers than just the two that I found (AliExpress,and Ebay)
Here's an image from the manual showing the relevant part of the schematic with the display module.
Imagem
(click on image)
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you so much for your answer, it seems that there are no replacements online so I don't think there's anything I can do to fix it.
por
Hi, sorry to bother, I found this website https://sony.encompass.com/model/SONDSCT...
I don't know which of the items listed would be the screen because in the descriptions I don't see anything about a screen so could you help me and tell me which one is the screen please?
por
Adicionar a sua resposta
Gaming With Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 32
Ao todo: 441
