Ir para o conteúdo principal
Um controle de videogame sem fio, mais tradicional, produzido pela Nintendo para o console Switch. Número do modelo: HAC-013.
Botched Pro Controller Joystick Replacement - Is it salveable?
Hi everyone, I tried to replace the left joystick on my Nintendo Switch Pro Controller. Unfortunately, as the title says, I botched it. I managed to desolder most of the solder points for the joystick, but I still couldn't detach it.
In the process of trying to get any residual solder off the mounting pads, I partially ripped one of them. I think I need to get solder flux to try to get the remaining solder to flow to detach the joystick. However, I want to get the opinion of those more experienced to find out if I passed the point of no return before proceeding. Pictures are below.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
is it the bottom left in the photo
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes it is. You can see the torn pad on the right side of the mounting points in the bottom left of the picture.
por
@smoothbrain looks similar to the pins above so i would say its a ground pin and fine to connect both together, so the bottom pin to the 1 just above with either a jumper wire or solder blob which ever is easier for you to do
por
Adicionar a sua resposta
smoothbrain será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 349
