Ir para o conteúdo principal
Guias de reparo e suporte para filmadoras fabricadas pela Panasonic.
How to fix a scratch lens
Hi, everyone, I have a couple of Panasonic camcorders in perfect shape other than I got a tiny scratch on the front lens on both camcorders, so when you record, certain ways the light enters the lens you see what looks to be a tiny bit of dust on your recording, and many people may not even notice it but I do a lot of filming and it bugs be crazy! Can I fix this without changing the lens which is nearly as expensive as the camcorder? Thanks for the help!
Update (12/09/24)
Panasonic HC-WXF1 and a Panasonic HC-VX1
Esta é uma boa pergunta?
Pontuação 0
2 comentários
wow thanks for your help, but that first lens(7:51 marker) that's removed is all I need! Where can I get this?
Thanks again!
por
So you feel the steps would be the same to replace the same lens on a Panasonic HC-WXF1 camcorder?
Thanks
por
Adicionar um comentário
1 resposta
Solução escolhida
@dmd31052 looks like you can get to the lens, but it is a bit of a PITA. See if something like {https://www.youtube.com/watch?v=1SLOYc4g... |this video] will help you to get to it. We'll continue to find some better material to assist you further.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
DMD será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 257
