Ir para o conteúdo principal
Monitor IPS LG UltraFine 5K de 27 polegadas com compatibilidade com o macOS
Monitor no longer powers on
The monitor no longer powers on, and does not connect or power my MBP. It sounds like this is a common issue. Has anyone else solved?
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
@harrisehsan does the power LED still come on? What have you checked? What is the exact model number for your monitor?
por
@oldturkey03 No it does not. Nothing happens at all. There is no real sign it is working. But I spoke to a repair shop that said the motherboard has known issues that cause this, so it should be repairable. Model number is 27MD5KA
por
Replace the motherboard then
por
@senopatib I'm hoping someone here can explain how
por
Adicionar um comentário
2 respostas
I couldn't find the exact monitor that you have but from searching maybe this could help:
https://youtu.be/ytKg1dsMv4U?si=pjGamcu9...
Esta resposta foi útil?
Pontuação 0
@harrisehsan don't replace anything yet until you have at least had a chance to take a look at it. Use this guide Desmontagem analítica do LG UltraFine 5K to get to the boards. Then post some well-focused pictures of everything with your Question. That way we can see what you see and hopefully assist you further. Adding images to an existing question - iFixit Repair Guide
I expect this to be an issue with the power supply.
Imagem de iFixit
Guia
Adicionar imagens a uma pergunta já existente
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de LG UltraFine 5K
Guia
Moderado
Pontuação 0
Adicionar a sua resposta
Harris Ehsan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 431
