Ir para o conteúdo principal
O Camry 2018-2024, que corresponde à oitava geração do modelo global Camry e é conhecido como XV70, foi apresentado no North American International Auto Show em janeiro de 2017.
Backup camera not working
I have a 2019 Camry; a few years after purchasing, the backup camera would occasionally cut to black while functioning, or simply show a black screen, while other times it worked fine. There was no debris on the lens and I saw no visible damage to the back of the camera or any of the easily accessible wires.
Since then, it cut out for good and has not resumed; every time I reverse, it's a black screen. Something must be working, because I do get the proximity "beeps" when someone is behind me.
Asked the repair shop and was quoted $1,500 - any suggestions?
Esta é uma boa pergunta?
Pontuação 0
4 comentários
I have some problem did you find any solution?
The electric shop asked me to get a new camera
por Compartilhar
Change the camera. Waterproofing in cameras Toyota very bad.
por Compartilhar
wth was the resolution?
por Compartilhar
Did you fix it ? I have the same problem, the fuses seems to be ok. It stopped working spooradically. Now it's toitally blank, I had some horizontal lines for maybe 15 secs befores it died. Looked like an old tv not tuned correctly to a channel;
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Hi @syracuse26
Have you checked that the #16 15A TV fuse in the passenger compartment fuse block is OK? Also are the reversing lights working OK?
UPDATE 12.2.2024
Hi @syracuse26
Here's the wiring diagram for the rear view camera system that may help.
It looks like there are two type of TV systems available unless one is just an enhancement on the other.
There's one known as a rear view monitor system (*6) and the other is a panoramic view monitor system (*5 & *8)
I've highlighted in a purple box the wiring paths to follow depending on which system is in use in your vehicle i.e. *6 or *5 &*8
There are 4 pages in the image.
Starting from the left the first page is just the power supply to the radio/navigation unit which seems to be working OK as far as receiving power so as to operate other reversing functions e.g. lights and proximity system etc.
The 2nd page is the circuit from the radio/nav unit to the cameras, either the rear view monitor on p.3 (*6) and/or the panoramic view monitor on p.4 (*5 & *8)
Perhaps check if there is power getting to the camera(s?) on the CB+ lead when measured to an earth (chassis), when reverse gear is selected.
If there is power at the camera then the problem could still be that the camera, the wiring (video wiring) or the radio/nav unit (as far as the rear camera circuit is concerned) is faulty but at least you know that the camera is getting power. Little steps I know but you've got to start somewhere.
Hopefully this is of some help.
Imagem
Click on the image and when it opens click on it again to further enlarge for better viewing.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hello - I just swapped out the TV fuse as suggested (it was in the engine compartment fuse box); no joy. Yes, reverse lights and all other electronics are functioning - nothing else is out.
por Compartilhar
Change the camera. Waterproofing in this cameras very bad.
Pontuação 0
1 comentário:
My reverse camera, in my Toyota Camry 2018 XLE V6 just black out in the display with RCD off message on my screen. I checked my fuses and reverse lights, they are working fine. So I decided to replace the camera with OEM from eBay (matching the bar code in the old camera (86790-06090). It worked and the display is back, BUT the reverse camera is so zoomed in that I can only see the floor with very little back view. I also have the message RCD off, visit your dealer !
Anyone knows what is happening, may be with this camera that I bought ???
por Compartilhar
Adicionar a sua resposta
Syracuse26 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 26
Últimos 30 dias: 175
Ao todo: 6,317
