Ir para o conteúdo principal
Guias de reparo, informações sobre desmontagem e resolução de problemas para o terceiro grande redesenho do popular computador de mesa compacto Mac mini da Apple, lançado em outubro de 2024. Equipado com SoCs M4 e M4 Pro e um mínimo de 16 GB de memória unificada.
How could I extend the power button cable?
I am working on an application that would involve me needing to extend the power button as the Mac Mini would be unreachable. Can you help me identify the power button clip and a potential way to extend the cable further?
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Has anyone found what connector is used? If we knew what connector was used (and could get a couple) It would be easy to wire an extension and move the power button wherever.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Depending on what your application is, I’m assuming it’s to restart as the process hung. If that’s the case then just leverage the AC power cord by placing a line switch within its path, as an example a power strip. If the application is just doing a presentation type of loop that would work. You could also setup a watchdog process from another system to manage the power strip if it has a remote control option.
Esta resposta foi útil?
Pontuação 1
@matthewtietje if by power button clip you are referring to the connector, we don't have that information just yet. Just like all of those connectors you can most likely remove it from the actual cable. We would need to see a close up of that connector to determine how to take it off. After that its straightforward, just extend the wires but either or using a cable connector to connect a longer cable (however long you need). Then connect a SPST normally open pushbutton switch to the terminals of the extension.
Pontuação 0
1 comentário:
Thanks. You can see the cable being unclipped in the teardown. Hopefully someone will identify it in the near future!!
por
Adicionar a sua resposta
matthewtietje será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 807
