Ir para o conteúdo principal
A HP PSC 2410 All-In-One é exatamente isso: uma máquina de fax, scanner, impressora e copiadora. Foi lançada em agosto de 2003 pela Hewlett Packard.
Sending and receiving a fax
I need to know how to find out what the number is for my fax for that I am able to send a fax and then the person I send the fax to is able to send one back.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
taylor parker, the fax number is the same as the phone number for the jack that it is plugged into. If your printer has a phone jack connector for a telephone, plug it in and call someone, like your own cellphone. Your number will show up. That will be the number for your fax. If you are using your fax from home, it will be your home number:-)
Esta resposta foi útil?
Pontuação 1
It may not be the most elegant way to find out, but you could send a fax to someone and have them tell you what number it is coming from.
Pontuação 0
Adicionar a sua resposta
taylor parker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 1,927
