Ir para o conteúdo principal
Informações sobre reparo e diagnóstico para a estação de energia portátil FixHub, a fonte de energia primária e a interface de controle para a linha de produtos FixHub da iFixit. Lançada em outubro de 2024.
Factory reset, CLI serial commands
Hi, does anyone know a command to return the FixHub to it's original shipped state?
Am thinking this would be via a terminal session, as the "knob" doesn't seem to show this option.
Also, is there any documentation on the CLI serial commands?
Some, like mcu-sn or toolinfo, are fairly straightforward, but am wondering if there's a comprehensive list of the other commands, similar to a man page.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
Hi @osxtra ,
There is no menu setting on the Power Station to reset factory defaults, nor is there on the web interface (currently).
In the meantime, these are the default settings:
Language (English)
Power-Off Timer (10 min)
Timer Enable (Enable)
Max Charge (100%)
Error Log (clear error log)
We also don't currently have a public spec for the serial terminal commands. We might in the future.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Tanks for the info, Kris!
por
I do not see the option "Max Charge" in my menu. Is this part of an update?
por
@omegatotal Yes, you should be able to see this option once the firmware is updated (not sure what exact firmware version number this would be when this option first appeared).
por
Nice 6 month turnaround
por
omegatotal, I see your 6 month turnaround and offer a seven.5 month one in return: ;)
CLI commands and STL files for the hub and irons can be found on iFixit's GitHub site:
https://github.com/iFixit/FixHub
por
Adicionar a sua resposta
osxtra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 531
