Ir para o conteúdo principal
How to: Keyboard replacement
Looking to replace the keyboard for my Envy x360 convertible 15m-dr0xxx
Would love to get a guide as I opened it up and it doesn’t seem a simple fix
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @auri16922
Here's the maintenance and service guide taken from this support webpage for the laptop series.
It details the procedure to remove/replace the top cover/keyboard assembly.
Basically you have to completely disassemble the laptop to do this.
On p.16 Item #2 you will find the HP part numbers for all the top cover/keyboard assemblies used in the model. Search online for the appropriate to your particular model part number only to find suppliers that suit you best. Usually the part number can be found somewhere on the underside of the assembly if you wish to verify that you're ordering the correct one.
Esta resposta foi útil?
Pontuação 2
2 comentários:
maintenance and service guide link dead
por Compartilhar
@mrthirteen
Try this link
por Compartilhar
Adicionar a sua resposta
auri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 35
Ao todo: 539
