Ir para o conteúdo principal
A Panasonic Lumix ZS50 (América do Norte) ou TZ70, TZ71 é uma câmera de viagem pequena, leve e pessoal, lançada em março de 2015. A câmera possui uma lente longa da Leica (zoom de 30x, 24-720 mm), sensibilidade aprimorada em baixa luminosidade, visor eletrônico integrado e resolução de 12,1 megapixels.
About problem while opening Lens Assembly
Can you give the pin details of the 6 pin ribbon flex cable inside the lens assembly that goes inside to the camera shutter in the DMC-TZ70, I accidently tear up that flex cable (while trying to clean the front lens), I want to connect it by jumper wire as those flex cable is not available in my country. ( upendradawadee.gmail.com; Nepal)
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
@upendradawadi that is one elusive flex cable. It's pretty difficult to fin out anything specific. I added the service manual to this page Panasonic Lumix ZS50 (TZ70, TZ71) under documents. It looks like the shutter flex connects to the Lens Flex cable. There is nothing specific in the schematic other than the LENS DRIVE BLOCK DIAGRAM on page 54, which does not give a clear indication what those points are. You may get some answers from the schematic and the Lens Flex cable on page 84.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I somehow manage that cable from old camera and lens assembly problem solved. But to clean the zoom Lever switch I opened the TOP PCB Unit, cleaned it and reassembled the camera, everything is done finely, now the camera work as before but suddenly I found the Flash is not working. But the camera system does not show any message on display about faulty Flash, so what may has happened in this TZ70 camera? Can you suggest possible step to finding out the fault??
por Compartilhar
Pergunta mais útil
@upendradawadi Can you show us a picture?
Pontuação 1
Adicionar a sua resposta
Upendra Dawadi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 439
