Ir para o conteúdo principal
Guides for the eMotorWerks (now Enel X) JuiceBox EVSE
Can we get ahold of Schematic diagram
In need of Juicebox Pro 40 schematic diagram. Do you have one?
Were in process of retrofitting Pro 40 w/ WiFi controller (for use via Alexa, etc.) to set Start & Stop times.
Any assistance will help ~15,000+ customers who have been thrown to wind by Enel.
thanx
Esta é uma boa pergunta?
Pontuação 1
3 comentários
Go to manualslib
por
@daytonwood do you have a direct link to the schematic on manualslib?
por
Just google manualslib.com or www then enter the item depending on the wording
por
Adicionar um comentário
2 respostas
Solução escolhida
@labear we all know that this is a common issue. There are hundreds of devices that have lost the support of the OEM and no schematics are available. This is why everyone on here is very much involved in the Right-to Repair. That is the insanity that needs to stop. Only thing I can suggest is that you continue to scour the internet and multiple other forums.
Esta resposta foi útil?
Pontuação 2
3 comentários:
go to manualslib.com
por
por
While I think the schematics should be available to anyone who wants to do it (eoecually given EVSE chargers are designed to cut off when they fail, or when put on a GFCI circuit they shut down at the charger level or breaker level), it's not a casual yes repair due to the voltages :/. Not something I'd be afraid of given I have taken on airbags/SRS issues, but yeah... Not everyone should.
por
Utube or manualslib.com
Pontuação 0
2 comentários:
@daytonwood have you checked? Are they available?
por
manualslib.com
por
Adicionar a sua resposta
labear será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 301
