Ir para o conteúdo principal
Dispositivos de comunicação sem fio, utilizados principalmente por árbitros.
Loose connection inside the rectangular rubber-coated case
Where would I start if I wanted to take this apart and re-solder it? Obviously would prefer to avoid any permanent damage. I've tried sliding a knife around the edges (there's a slight ridge where what appears to be two halves were pressed together), but I'm guessing I need heat and/or some kind of solvent. Anyone have experience taking apart weatherproofed / sealed electronics?
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@miketexter post a couple of well -focused images of the "rectangular rubber-coated case" with your Question. that way we can see what you see and hopefully assist you further. Adicionar imagens a uma pergunta já existente
por
@oldturkey03 done, thank you for that tutorial :)
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@miketexter that looks like it's very well glued together. If this would be mine, I'd take an exacto knife (or a razor blade) and cut through the seam. After completing the repair, I'd use some silicone rubber glue to reassemble the case.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mike Texter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 188
