Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Android topo de linha S21 Ultra da Samsung, lançado em janeiro de 2021. Também conhecido como Samsung SM-G998U1
Cracked screen flickers -temp fixes?
I broke my screen and there's a bit of glass missing on the edge. A horizontal line has appeared by the crack and the part of the screen below this often flickers green /goes dark. I found that if I play with it a bit it stops, especially I noticed if I push something fine in the crack it comes back to normal for a while (I have resorted to using the back of my earrings for this!).
I am not in a place to buy a new phone yet, and fixing this would cost about the same. My phone works perfectly besides this issue so I would like to use it as long as possible.
I've seen people suggesting to put glue or nail polish on cracked screen, but my hole is so deep I am worried this would ruin the whole screen.
Does anyone have suggestions on what I could safely put there that won't cause further damage?
Thanks !!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
you could try loca glue and cure it with a uv light as this glue is for bonding glass to lcd panels on phones, other than that a replacement screen is less than £80 on aliexpress
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Claudia Presti será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 22
Ao todo: 269
