Ir para o conteúdo principal
iPhone de quarta geração. O reparo é direto, mas o vidro frontal e o LCD devem ser substituídos como uma única unidade. Capacidade de 8, 16 ou 32 GB GSM / Modelo A1332 / Preto e Branco. Esta página tem como objetivo ajudar a comunidade a solucionar problemas, consertar e buscar ajuda para o iPhone 4.
How to Install Itunes For iPhone 4 .
How to install iTunes on iPhone 4 device. And how do I install it? And can i install myself.
Esta é uma boa pergunta?
Pontuação 2
7 comentários:
To be clear, the iTunes app itself isn't appearing on your device?
por
This question is really vague. Like it could mean what version to install on Mac or P.C to connect the phone for certain exploits or anything 🤷‍♂️
por
@muhammadsa29369 We prefer you not hold private conversations with our contributors, as the purpose of this site is to help others. As such, any assistance you get in private helps you and only you, whereas posting a question on this site allows everyone to benefit from whatever you learn.
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
iTunes is installed by default when you got your phone. Did you remove it somehow?
Depending on the version of iOS you should be able to see it looking at the icons it’s a Purple box with a White five point star in it. You can also go into search and type iTunes to locate it if it’s not visible.
If you removed it you’ll need either use this to access it via the iPhones Safari web browser How to Download built in Apple Apps for iOS from the App Store. Or connect your phone to a Mac system with iTunes to re-install it.
Esta resposta foi útil?
Pontuação 0
@muhammadsa29369 not sure why you would want to install iTunes on your phone. You do not need it to play music. For that you use the innate App "Music". Where you do need iTunes, is on your computer. You use that to sync your iPhone with your computer, not the other way around. Remember, your iPhone cannot be upgraded with anything above iOS version 7.1.2
Do not get confused with the iTunes Store App, which uses a purple box with 5-pointed white start in it, as icon. That is not the iTunes you need to sync your music/files :-)
Pontuação 0
Adicionar a sua resposta
Muhammadsalim Mamadaliyev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 729
