Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
3 comentários:
@devanshu92258 are you saying that your TV does not turn on, no matter which button you push? Dud you check the electrical outlet where it is plugged in to? You have checked the power cord? Does the power LED turn on? Does your TV show any sign of live?
por oldturkey03
I have the same problem, no red LED when it is plugged in and the power supply circuit seems intact
por Nicolas El Reda
@nicolaselreda
What is the model number of the TV?
Did you check if the fuse on the power board in the TV is electrically OK by testing it with a DMM (digital multimeter)?
por jayeff
