broken screen, is there any solution?
My Kindle stopped working and stayed that way, I have tried to fix it by disconnecting everything and it doesn't work.
Esta é uma boa pergunta?
Hi @bvsty
You may have to replace the screen.
What is the model number of the tablet as shown at the bottom of the back cover?
Not all Kindles are the same i.e. different LCD flex cables/connectors etc, so knowing the model number will ensure that you get the correct replacement part.
Esta resposta foi útil?
Is the modelo J9G29R
Thanks for the help.
Hi, I have the model J9G29R and it has a broken screen. I have a replacement screen. Was able to open up the kindle based on below guide but I have not been able to find any videos to show how to actually remove the screen to replace it - it appears to be glued on or something - any help??
here is ifixit guide on how to disassemble the kindle
Substituição do conjunto do display do Kindle 10
- thanks
where did you get the replacement screen from? I can't find anything online
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 710
