Ir para o conteúdo principal
LG icemaker not dumping ice
Freezer is set at 0 degree F. Refrigerator set at 37 degrees F. Water fills the ice holder and freezes properly, however the ice is not "dumping" the ice into the ice bin. I can use the rest button to manually dump the ice and the water will refill ice holder, but then the icemaker will not dump the ice on its own. Why?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Hi @gary26442
What is the model number of the refrigerator?
por
LG refrigerator LFX23961SB
por
Now the ice won't freeze in ice maker and won't keep the ice in the bin frozen...ugh
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @gary26442
Here's the service manual that may help.
Go to p.24 thru p.26 to view how to test the ice maker functions.
On p.34 & p.35 there are some ice maker voltage test points on the control board and at the back of the manual there are parts diagrams and a parts list. If you find the problem is a faulty part, locate the part number and then search online for the part number to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
gary será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Ao todo: 642
