Ir para o conteúdo principal
Heat Resistant Clamp options
Anyone have any good options for heat resistant device clamps?
Ultimately, trying to avoid unnecessary finger burns when holding down circuit boards when chipping off or soldering etc. Seeking something that can withstand chip-off heat but keep devices held in place.
Imagining something phone/tablet sized that has heat-resistant clamps that i can move around on a soldering pad under a microscope.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@kyle55124 I use the PCB holder from my reball station for pretty much all that type of solder work. Might be a little big for what you have in mind but it could be cut to size with a hacksaw or similar.
If you are handy try something like this and you can get the plans from here you can always refine it to suit your needs.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kyle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 317
