Ir para o conteúdo principal
Também chamado de Crosley Musician Entertainment Center.
CD drawer stuck closed.
Where is the auto release hole located?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi @jameshubba14635
There is no release (or eject) hole in the CD unit.
Use a thin flat tool e.g. flat metal spudger or even a suitably thin knife etc and slide it gently under the CD tray, on the left side until you feel the catch release.
Esta resposta foi útil?
Pontuação 2
2 comentários:
It didn't work. I felt something catch but which way should I move it? I tried up/down/right/left
por
Under the disc port there should be gears on the left side use a flashlight and look into the hole and grab something thin hard and long enough to fit in the hole I used a knife but all you do is push the gears and they should start turning and when the disc slider pulls out enough for you to be able to grab it pull it out the rest of the way
Pontuação 0
Adicionar a sua resposta
jameshubbard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 14
Últimos 30 dias: 61
Ao todo: 845
