power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
Esta é uma boa pergunta?
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
Esta resposta foi útil?
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
The question is still open, are those part numbers interchangeable or: what's the difference?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 7,233
7 comentários
Hi aaronoehlke. Did you find the power supply board for sale?
por SW
I also need this - it makes a weird noise - and it is coming from the power supply...
por Antonkjaer
Have you got the power supply?
por Karsten Bundgaard
Hi Karsten,
Nope - have you got one in Denmark?
por Antonkjaer
Unfortunatly not!
Exibir mais 2 comentários
