What model battery is inside?
What type of battery is inside the Robosen Optimus Prime and how do you replace it?
Esta é uma boa pergunta?
@rtecbot little did I know this beast even existed. Dang. Quite a price tag. Anyhow, they keep this a bloody secret. Here is a bit of information that I got.
External Photo 5145877Robosen Optimus Prime Internal Photo 5145878
Esta resposta foi útil?
I wasn't able to tell from the pictures, but would the battery be the same for the Flagship edition? That's the one sold earlier and is several inches taller. Mine no longer holds a charge and I am hoping against hope that there's batteries I am replace (and some kind of documentation on how to do so).
@bakersysadmin I couldn't even guess on that one. I assume that this battery most likely will be the same. If you find a way to the battery, let us know. Take lots of pictures so you can create a guide (iFixit is always willing to help with that as well :-)
The battery is a batterypack an 11,v / 12,6v
1200mah 13,32wh.
Its a battery pack that consists of 3 x 3,7v put together.
Located behind the grill, you have to unscrew it with four screw on the backside of the grill, but to get to two of the screw youll ned to dismante "legskirt" and the legs/servos from the hip. The battery is set up with a quickconnector and is really bad and 100%chinese.. mine wouldnt charge and the batterypack was even bloated! Straight out of the box! Shipping to my location is 500usd, so i decided to figure the $@$* out for my self..
Hi! Can you please give some short instructions about how to dismantle legskirt? Tryed for 1 hour with no luck and dont want to break(
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 50
Ao todo: 1,836
3 comentários
por Andrey Belik
If you have found a way to solve the problem, and where you ordered a spare battery, I will be very grateful
por Nikolai Bobrovskii
Can you please share what battery you bought to replace the old one and if it worked. Thank you
por Raluca Neacsu
