Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
A1181 Inverter Replacement or Screen Replacement?
My Core 2 Duo has a problem with the back light, whereby the back light may work for a small amount of time, but will then turn off, regardless of if I have moved the position of the display or not. The only way that I can get it come back on again is by closing the lid of the laptop, then opening it again, and even then once it has gone off once most likely it will just turn on again for a second or two and then turn itself off again.
From other posts that I have read it seems that most people suggest changing either the inverter, the inverter cable or both, therefore I have bought both of these items. I replaced the inverter first as this seemed like the easiest thing to do, and for about a day or so the back light seemed to come on fine, but its back to its old trick of turning on for an intermittent amount of time, then turning off.
I had thought about changing the inverter cable, though I don't think that this is the cause of the problem, as the back light will turn off randomly, without moving the angle of the screen (and therefore the cable) at all, so I don't think it is worth the hassle of changing this.
I wondered if the inverter that I have bought is also faulty, though it should have been a new genuine Apple part and had the same model number as the original (607-1961). Changing the inverter did seem to temporarily fix the problem and even now it seems to have improved the amount of time that the screen stays on for compared to the old inverter. Or maybe I should buy a new screen and replace that? This problem sounds similar to the one posted here (Backlight works for a split second, inverter or inverter cable?) so this makes me think I should now replace the screen and assume the replacement inverter works correctly.
If I did buy a replacement screen, all of the online retailers have a 90 day returns policy, therefore I feel that I should be able to return it if it is not needed, however it would be very useful if anyone can tell me if I should be able to test the screen connected to the laptop without fully fitting it first?
Thanks.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
If when it goes dark you can still see the desktop, it is most likely an inverter or inverter cable issue. If it's going totally black the issue is most likely with the LCD. Hook up an external monitor to rule out a GPU issue. Did you get the new inverter from a reputable source or off eBay?
Esta resposta foi útil?
Pontuação 4
2 comentários:
The inverter was bought from eBay, but from an eBay shop that was supposed to be reputable. I take it if an inverter is failing that it may work for an intermittent amount of time, rather than always not working, or say always turning off after a similar amount of time once it gets hot? I have got another inverter from a different source now so I may try that to see if that makes any difference.
The screen never goes completely black so you can always see the image regardless of how bright the screen is, however I thought that if the back light of the screen was playing up then this is what you expect to see?
Thanks for your quick response.
por
I've seen inverters that do work for a time and then shut down. So you seller may have done a quick test and it worked.
por
Adicionar a sua resposta
robT será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,928
