Ge monogram oven problem
Probe light kept blinking on and off on display and couldn't start oven. Replaced probe and receptacle, still blinks. Should I replace the control panel board or main machine board?
Esta é uma boa pergunta?
Hi @bob57707
Here's the mini manual for the oven.
It shows how to test the temp sensors to prove that the sensor wiring and the sensors are OK back to the board, - see Oven Sensor and Door Switch Ohmmeter test on p.1
If they test OK run the service test mode as described on p.2 and check what error code is shown (if any) when testing the components.
If a part is faulty and needs to be replaced, here's a parts list that is useful as it shows the manufacturer's part number listed for each part.
Search online for the part number only to find suppliers that suit you best.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 29
Ao todo: 511
3 comentários
This question was migrated from https://meta.ifixit.com/Answers.
por iRobot Compartilhar
Hi @bob57707,
What is the model number of the oven?
por jayeff Compartilhar
@jayeff hi, model number is zet1sh1ss
por Bob Compartilhar
